screwed up launchy, please help?
Hi. I set launchy to "launch" with alt+tab. But now when i press alt+tab only the windows feature kicks in (revolving through active programmes) and i seem not to be able to run launchy anymore so i cant change the options. :angry:
Obviously i tried uninstalling and re-installing but to no avail. Is there no solution to bringing up launchy options?
Thanx!
You may want to check out the official Launchy Documentation and Help, and their forums and discussion on the Launchy SourceForge.net Project Page.
documentation didnt help any, will try the forum though!
If you set the keys that bring launchy up to something you forgot or that doesn't work, go into c:\documents and settings\username\application data\launchy\launchy.ini open it with notepad.
hotkeyAction=32
hotkeyModifier=134217728
change those values back to that. those values correspond to alt+space.
Sometimes launchy launches way off screen. To fix this, open above file and...
[Display]
pos=@Point(1 1)
change that value to something within your screens resolution. (1 1 will be in the UL corner of the screen).
Try Keybreeze :)
http://keybreeze.com
