Scheduled Defrag Issues
I've noticed the following bugs in Defraggler:
  • On install of upgrade (to v2), Defraggler setup doesn't detect if scheduled defrag tasks are currently running.. (Error message during install is unable to access df.exe)...
  • The Scheduling doesn't seem to work when no one is logged in by default, unless the scheduled task is modified manually afterwards...
Otherwise, thanks for the great product - I use it heaps! :)
Chris
