Schedule CCleaner Cleaning
I would like to suggest that in the next version of CCleaner that you add an option to schedule a time for CCleaner to run. This would be helpful for those of us that don't turn off our computers. I have mine set to turn off the monitor. It would be nice to have a way to program a time that ccleaner would clean things. Like to be able to set it to run at 3:00AM when the computers aren't being used. Right now it only cleans at startup or shutdown. But because I don't normally shut my computer off, it doesn't run regurally. So please give this some consideration in future versions of CCleaner.
Thank You.
Have you considered using Windows Task Scheduler to run CCleaner?
Just to expand on Majestics good suggestion ...
Command-line parameters for CCleaner operation: (Scroll to this heading)
And spookily enough, the docs actually mention running it a 3.00am.
