Hello !
before CCleaner, I rebuilt the basis of the registers under MS-DOS with the order: SCANREG/FIX
Is this even necessary with CCleaner ?
Thank you
Hello !
Thank you
All that does is fix the registry if there's an issue, moreover to rebuild/compact it, basically "registry defrag." CCleaner has no functionality to do that to the registry under Win9x systems with DOS.
