Scan users "LocalService" and "NetworkService"
Some virus are using the user "LocalService" or "NetworkService" to download from Internet. This can cause a lot of temporary Internet files in those users.
Theses folders are concerned (on XP) :
C:\Documents and Settings\LocalService\Cookies
C:\Documents and Settings\LocalService\Local Settings\History
C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files
C:\Documents and Settings\LocalService\Local Settings\temp
C:\Documents and Settings\NetworkService\Cookies
C:\Documents and Settings\NetworkService\Local Settings\History
C:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files
C:\Documents and Settings\NetworkService\Local Settings\temp
Thank you
[LocalService Cookies*]
LangSecRef=3025
DetectFile1=%SystemDrive%\Documents and Settings\LocalService
DetectFile2=%WinDir%\ServiceProfiles\LocalService
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Cookies|*.*|REMOVESELF
FileKey2=%WinDir%\ServiceProfiles%\LocalService\AppData\Local\Temp\Cookies|*.*|REMOVESELF
FileKey3=%WinDir%\ServiceProfiles%\LocalService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|REMOVESELF
[LocalService History*]
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\History|*.*|RECURSE
FileKey2=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[LocalService Temporary Files*]
LangSecRef=3025
Default=False
FileKey2=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Temp|*.*|RECURSE
[LocalService Temporary Internet Files*]
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Temporary Internet Files|*.*|RECURSE
FileKey2=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
[NetworkService Cookies*]
LangSecRef=3025
DetectFile1=%SystemDrive%\Documents and Settings\NetworkService
DetectFile2=%WinDir%\ServiceProfiles\NetworkService
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Cookies|*.*|REMOVESELF
FileKey2=%WinDir%\ServiceProfiles%\NetworkService\AppData\Local\Temp\Cookies|*.*|REMOVESELF
FileKey3=%WinDir%\ServiceProfiles%\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|REMOVESELF
[NetworkService History*]
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\History|*.*|RECURSE
FileKey2=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[NetworkService Temporary Internet Files*]
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Temporary Internet Files|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Content.IE5|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey4=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Content.IE5|*.*|RECURSE
[NetworkService Temps*]
LangSecRef=3025
DetectFile1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp
DetectFile2=%SystemDrive%\Documents and Settings\NetworkService\Temp
Default=False
FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Temp|*.*|RECURSE
+ 10,000
I wanted this forever. It makes cleanup a LOT faster than having to manually do it.
Otherwise, any scans/defrags/fixes will take forever, because viruses that do this typically have 10,000+ tiny files in that "user account" which causes high fragmentation, & verrrrrrryyyyyyy slow scan times!
_____
WinApp, thanks for the key. Can you post it as a downloadable .ini file?
I'd love to use it (temporarily) till they get around to adding it in!
+ 10,000
_____
It'll be in the next winapp2 :)
Question :-
Do we need 8 separate checkboxes for purging 8 sets of malware ?
Would it not be faster execution and a cleaner GUI to have only one checkbox with only a single Detectfile1 plus a single Detectfile2 to trash all 8 nests of malware ?
LangSecRef=3025
Default=False
Is FileKey1 correct?
nope, that should be
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Temp|*.*|RECURSE
Ok, these are just for Windows XP only. I've made a few changes to what Winapp2.ini originally posted for the Windows XP locations because some locations are instead hidden inside of a \Local Settings\ directory. I've tested them on my system and they work, they even get rid of index.dat files which aren't locked/in-use.
[XP LocalService Cookies*]
LangSecRef=3025
DetectOS=|5.1
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Cookies|*.*|RECURSE
[XP LocalService History*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\History|*.*|RECURSE
[XP LocalService IETldCache*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\IETldCache|*.*|RECURSE
[XP LocalService Temp*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\Temp|*.*|RECURSE
[XP LocalService Temporary Internet Files*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\Temporary Internet Files|*.*|RECURSE
[XP NetworkService Cookies*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Cookies|*.*|RECURSE
[XP NetworkService History*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\History|*.*|RECURSE
[XP NetworkService IETldCache*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\IETldCache|*.*|RECURSE
[XP NetworkService Temporary Internet Files*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files|*.*|RECURSE
[XP NetworkService Temp*]
LangSecRef=3025
DetectOS=|5.1
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temp|*.*|RECURSE
I've revised mine accordingly
A server of ours (Windows 2003) has also had bad trojan related files show up in this directory:
C:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\
How can I view what files are in there? Even if I type my way through Windows Exploer to that directory it looks empty, but I know there must be CONTENT folders in there as that's what our AntiVirus software reports when it finds stuff there.
I want to see what other files may exist that our AV software is missing.
Any good help appreciated. Thanks!
You really need as a matter of urgency to seek help with the malware you have.
Please see this post here
http://forum.piriform.com/index.php?showtopic=34786&pid=208046&st=0&&do=findComment&comment=208046
We don't give malware related help on forum anymore
Try TreeSize
http://www.jam-softw.../treesize_free/
TreeSize can show files which are "super hidden" from Windows Explorer.
Because I have refrained from bypassing default protection I cannot navigate Windows Explorer to look inside the folder
C:\System Volume Information\
But using TreeSize to scan C:\ and a few seconds later it shows me all I got.
and two clicks later it launches Windows Explorer over the "barrier" and I have access to
C:\System Volume Information\SPP\
Then using Windows Explorer I can examine file properties and copy to more accessible paths files such as :-
C:\System Volume Information\SPP\OnlineMetadataCache\{31c7a734-4c32-4e53-9e50-ebb3e86137e3}_OnDiskSnapshotProp
Hazel Ninja's me.
I answered you technical question but Hazel's advice is more relevant to your needs.
Open My Computer, & select Folder & Search options from the drop down menu. Unhide both System & Hidden files, then OK.
You will be able to see the files. If you still cannot see it, try copying the temp internet files folder to a different location, such as your desktop & they will be visible.
Then, reverse the process to hide them back when your finished.
Edit: You can also do like Alan suggested. 3rd party explorers that show hidden files by default.
The user has been advised to seek Malware Removal assistance.
Please do not add anymore recommendations for spacewalker0720 or I will remove them and close this thread.
