As a new user, I would like advice on which boxes should be checked (or unchecked) under WINDOWS and APPLICATIONS. Are the default settings as downloaded optimum, or should I make changes?
Thank you for your response.
dontknowsquat
dontknowsquat
Which application are you referring too??
Richard S.
If you are referring to CCleaner, just leave the settings at default for now until you are more comfortable with the program.
Documentation....
Thanks Hazelnut,
I checked out the link you provided. I will study the documentation and proceed from there.
I am IMPRESSED in this world of no instructions to have a complete set of instructions available to read and use.
dontknowsquat
