Saving passwords
Good afternoon from Idaho
I have been a user of CCleaner for a very long time,I usually run the cleaner at the end of day and for some reason it always clears my yahoo login and password but my Hotmail is fine,the "saved passwords and network password) boxes are unchecked,just curious if I'm doing something wroung or can I only save one
Best Victor
Try keeping all the Yahoo cookies.
IIRC yahoo uses a flash cookie. However you can go to options\cookies to keep in ccleaner you should be able to move yahoo to the right hand column (look for yahoo.com, www.yahoo.com, or most things from yahoo (be careful of advertising cookies though)
Nergal,Thanks for getting back to me,DONE !! also added dns catch to empty all the other unwanted cookies
Best Victor
