Saved form info not being wiped
I have been using CC for about 6 months. After the last update I noticed that previously used "usernames" were no longer being wiped after running CC (v2.35.1223). I typically use Chrome and I have the box checked to clean "Saved Form Information".
Did something change in the latest version? Am I doing something wrong? I share the PC with others and really don't want them to see my usernames so what can I do to remedy this situation.
Thanks.
Which version of Chrome are you using?
Are you sure this ONLY happens in the latest version?
I'm using Chrome v6.0472.63. And yes it CC always used to wipe the usernames when I ran the cleaner. For instance I have 2 email accounts in different packages that are similar. After running the cleaner if I type the first letter (the same in both user names) in one of the packages both names appear. This never happened before the last update for CC.
Thanks.
