Save CCleaner settings
Hi,
At the outset letme say that CCleaner is a wonderful utility!
Is there a way to save all settings - custom folders, cleaning options, cookie lists - such that these can be re-applied back in case of having to re-install the OS?In this case Windows XP Pro SP3.
Regards and TIA.
Jyanendra
Welcome the forums jyanendra. :)
1. Start CCleaner.
2. Click Options->Advanced.
3. Tick this box: Save all settings to INI file
4. Close CCleaner.
5. Open: C:\Program Files\CCleaner
6. Copy CCleaner.ini to another medium or ZIP or whatever off your C: drive to have a good backup copy. Remember to update your backup should you change your CCleaner settings.
If you need a batch file to re-install CCleaner.ini from the backup here's mine (copy+paste into Notepad, then save as "CCleaner INI Installer.bat" with the quotes then place it with your backup copy of CCleaner.ini):
@echo off
echo.
attrib -r +a "%programfiles%\CCleaner\ccleaner.ini"
xcopy /v /y "ccleaner.ini" "%programfiles%\CCleaner"
echo.
echo.
dir "%programfiles%\CCleaner\*.ini"
echo.
echo.
pause
cls
exit
