Save advanced cleanup settings
Is there a way to save the settings I’ve made? Having to re-enter them every time I use the app is very tedious.
Hi @luma,
Please could you send me a screenshot of the settings you are asking about so I can advise you further.
Hi @Laurence_CCleaner
Of course! My question relates to the customization options in all three tabs (Junk / Browser / Registry).
Thx
Luma
Thanks @luma, if you perform a scan after changing these options, this will save the settings for the future.
It works!
Thank you so much for your support!
Best regards
Luma
Glad I could help :smiley:
