Speccy does not properly identify the new Samsung 970 Pro NVMe M.2 SSD. See pic
Probably because the 970s uses a new controller than the 960s/850s did. The 860s probably don't get detected, either, as it is the same controller as the 970s.
Yep, the 970 and 860 SSDs are quite new. I just noticed that Speccy is not identifying the G-Skill RipJaws DDR4 RAM sticks either (unknown)
Don't worry - it will be fixed by 2021.
