mine AVG detects it also But im not afraid
You may want to contact them and say it is not
AIRPORT101
AIRPORT101
AIRPORT101
That's your choice. I'm just presenting facts.
Changelog 1.0.2
Fixed bug with "problem with shortcut , searching for file gui"
Fixed false positive warning with AVG antivirus
(Thanks to Lusher for reporting the bug)
Hmm the author "fixed" it so it is no longer detected by AVG. Plus fixing another bug I found
. . .This is harmless, don't believe me, use a packet sniffer and you can see exactly what is being "sent". . . .
Thanks, LUSHER, for the information.
http://www.runscanner.net/download.aspx
Changelog 1.0.3
Added trusted zones HKLM
Added HKCU\Software\Classes\Folder\Shellex\ColumnHandlers
Added HKCU\SOFTWARE\Microsoft\Active Setup\Installed Components
Added HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
Added HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
Added 105 HKCU\Software\Microsoft\Internet Explorer\MenuExt
Fixed minor bug with incorrect filter
Fixed minor sorting bug in text log file
Changed behaviour with 068 -> download lsp-fix
Changed ctrl+c (copy) formatting
Google lookup now also searches for GUID, registry entry if no exename available.
