Running Erunt on Vista startup with UAC
Link to: Automatically Backup Your Windows Vista Registry Daily Using ERUNT
When I installed ERUNT I got the UAC pop up, so I removed the startup item AUTOBACK from the Startup folder.
I did manual backups when I remembered too, until today. B)
The only thing I added was the command line switch /days:3 at the end of the Add arguments (optional) text box.
%SystemRoot%\ERDNT\AutoBackup\#Date# sysreg otherusers /noconfirmdelete /noprogresswindow /days:3
ERUNT AUTOBACK is set for 30 days which is to many for me.
The number of restore folders to keep can be changed using the /days:n
command line switch, e.g. /days:7 would only keep the folders from the
last 7 backup days.
I also cleared all boxes under conditions.
