I have a computer that is the property of my company and used for work only. CCleaner has done wonders on my home and personal computers and I'm wondering if it is safe to download CC on my work computer. I'm not exactly sure of my company's policies and download rules.
I would check with your company first as to their policy on this sort of thing. We don't want you to lose your job
Welcome to Piriform bossox.
My company used to install CC on all machine because I had an old version on mine I asked them to please update it. The reply was CC is for private use only and its also a registry cleaner which they don't like. So I put the CC folder on a flash drive and set it to use the ini option. I copied the folder into my personal folder on the server and I run it from there, st**f them.
You are lucky if your company gives you admin rights to install anything, ours doesn't. You are better of checking with your company just to make sure.
