I have a windows 8.1 computer and a 64 bit operating system. Will it hurt my computer if I run CCleaner on a daily basis? I have a Dell inspiron 2350 computer with a Western Digital SATA hard drive. When I run CCleaner my computer seems to run faster. Thanks
As long as you don't have Wipe Free Space enabled and turn off multiple wipes, there should not be harm done. Those two options I mentioned cause more wear and tear on your hard drive than a normal clean would.
Thank-you
I don't have wipe free space enabled. I do not see anything about multiple wipes. I have version 5.10.5373 and I have not made any personal changes. Whatever was checked when I downloaded this version that's what I went with. I am not talking about the registry cleaner.
Perfect, yes then it would be correct to assume no harm would befoul your pc or at least no more than would occur with regular computer use
