I've seen a few comments here about getting CCleaner to run on Vista without
the annoying UAC prompt that pops up all the time.
Well, you can set any program to bypass UAC on vista using this method:
Using this you can leave UAC on for safety, but select a few applications that
you trust that can bypass it.
I use this with CCleaner and it works fine. The only problem is that I
cannot work out how you set CCleaner to automatically clean when
it runs. The /Auto switch does not seem to work using this shortcut
method.
Anyway, enjoy...
