'Run Cleaner' button problem. v5.43.6522
Hi, I'm here to report a problem with the latest Ccleaner v5.43.6522.
The 'Analyze' and 'Run Cleaner' buttons are not clickable (greyed out) for about half a minute when I run the program, after this time they become available.
I remember previous versions taking a few seconds before they came on, but 25 seconds / half a minute or thereabouts, not good.
Using Windows 7 home premium, i5.
g'day sinibomb and welcome to the forums.
do you use winapp2.ini or any other enhancement to CC?
Hello mta, no I don't have that, I downloaded something called [Voldemort] but didn't need it so uninstalled it. I'm sure it did it before that though.
2 hours ago, Sinibomb said:
Voldemort creates a winapp2.ini check your program folder to see if it had already done that. This is the most common cause of the issue you describe.
There's a winapp2.ini in the main CCleaner folder, should I delete it? (I'll move it to recycle bin temporarily and see what happens) Also why has the program I mentioned been changed to Voldemort. The program I mentioned is related to ccleaner surely! Let me try this again: [voldemort].
Hey deleting it worked, thanks Nergal.
Use of the enhancing program is not allowed to be mentioned thus voldemort (that which must not be named)
