In the files defrag view of Defraggler, would it be possible to add the option for a user to tick at the top where they can get Defraggler to sort files into the folders they belong in, and offer the ability to just select a folder to defrag, or even enable a user to right click an entire folder & defrag it right from within Defraggler files list itself?
In the case of a user with a folder that has thousands of files to defrag, this would vastly speed up defrag!
Defraggler would still just defrag the fragmented files like always, just that a user could select, say, "Windows" & all windows files that were fragmented would be immediately defragged.
I think this would be much faster!
Just be sure to show the number of fragments beside each folder so a user can quick glance & see what ones need defragging the most!
