Review of Defraggler
Just wanted to point out to a review of defraggler I did here:
http://www.windowhaxor.net/2008/04/17/defr...k-defragmenter/
You couldn't of said it any better :) Great looking write-up!
Defraggler is good and getting better all the time.
Most users just defrag everything.Then they complain it takes too long or hangs on large files.
Most of these files don't need defragging any way.
I just hope that they keep the Prefetch folder and User Assist history in mind.
Plus keep the average user in mind and ignore such files as mentioned above.
I also would like to see some of the Vista SP1 defrag startegies incorporated or updated in XP.
"Average" users get along fine with Windows Disk Defragmenter.No hassles at all.
"More Advanced" users(more understanding of disk management) use Defraggler.
Yes ,I have used JkDefrag and I find it to be of great advantage to "very knowledgable" users.
:) davey
Hi Everybody,
Thought you might like to see the latest Defraggler update from http://donnedwards.openaccess.co.za/
Sunday, April 27, 2008
Another Look at Defraggler
:) davey
Sweet deal...publicity is always a good thing!
AJ
AJ
Yeah and this time around Defraggler is going to be in the Shootout.
Bang!!! Bang!!!
:) davey
Nice review pavs :)
It's good to see some publicity for defraggler, mostly because the developers aren't paid to do this..
Thanks for posting a review, pavs. I did see that you reviewed another defragmentation utility, Power Defragmenter, less than a month before Defraggler (the review is posted here). Which would you say is better? Thanks.
