Is there any way for ccleaner to return the results of how much data was deleted when running ccleaner /auto from the command line? We have a remote monitoring agent that allows ccleaner to run but it just says successful or failed as there is no text output on how much was deleted.
As an example - When you run the standard windows cleanup, the result of the run is hpow much was deleted so that is sent into out remote administration console.
