That would mean that 3,104 fragmented files were only 1.2GB of the total 43.9GB and 8,771 total fragments was only 2% of the total 50% and the other 21 fragmented files with 97 total fragments are the majority. That may be right but it sure does not look right!
"...have you tried running DF with Stop VSS option ticked and Exclude restore point file & Exclude hibernation file options both ticked?"
No but after I install the latest version I will select those options and then run it again.
