i,m facing recently this problem .i, m using cclener since 6 years but this is the 1st time of that problem.
No restore point seen in ccleaner! (restore points present/confermed in windows >system tools >system restore).but not seen in cclener relevant window.
let me know that ,is this problem, due to setting in ccleaner? or... a bug?
I've experienced the same problem with the latest release of CCleaner (v3.02.1343) and Windows XP SP3. Although System Restore was showing previous Restore Points, CCleaner was reporting none. The work around I found so far was to turn off System Restore and then turn it back on again to clear the previous Restore Points. CCleaner will then start recording the Restore Points.
Windows XP SP3, and CCleaner picks up my Restore Points fine.
It could be one of these odd XP glitches which pop up occasionally. Turning it off and on again as mentioned by Majestic, would be worth a try as long as your pc is running fine and your happy with all your installations.
EDIT: Alternatively, you could try an earlier version of CCleaner to see what happens.
