I found RP has big number of bytes ( 1.075 MB)
Is it safe to delete RP,partialy ?
and this morning,I also found my free space decreased dramatically ( 18GB to 17.6GB ),why ?
I didn't install or uninstall any program.
Are you using vista or xp?
Here are some Q&A's on vista
http://bertk.mvps.org/html/q_a.html
In XP you can cleanup all but the most recent restore points. Obviously be sure you won't need any old ones before you do this...
Click Start, and then click My Computer.
Right-click the disk in which you want to free up space, and then click Properties.
Click the General tab, and then click Disk Cleanup.
Click the More Options tab, and then under System Restore, click Clean up.
Click Yes to remove all but the most recent restore point.
Click OK, click Yes to proceed with this action, and then click OK
Thanks a lot,Hazel
