Restore Default Settings
As with ccleaner, and this should go on every program, the restore default settings button.
In defraggler, it can be located under: Settings -> Options -> Advanced Tab
+ 1
Would be very nice in some situations.
Of course, you can also delete the .ini settings file, & generate a new one, but you might lose custom files or folders, or even includes/excludes lists.
Examples of situation this would be handy for, is when user(s) resize the program or change a lot of settings. Users may want to reset the default settings without losing custom folder lists, so that they are able to use it portably.
CCleaner has this for the individual cleaning entries, if you right click on their headers and select Restore Default State
Ah! So nice to know, WinApp!
What we learn from each other!
I was unaware of that prior to this, & you, my friend, have learned me something new!
Very, very cool, & very, very nice.
Thank you for showing me that!
There is no master reset, so it has to be done per section. Not much more work, but a central button would be nice.
