Restore After Running CCleaner
Hi guys
I've run CCleaner for a while on older machines. Recently I bought a new Win 7, Dell Precision 6700, 64bit laptop and after several months I want to run its first clean-up (I always run a registry back-up when I run the registry clean).
As this is a new laptop I don't want to banjax something, so I did a bit of surfing to confirm about using CCleaner and I'm a bit confused. I thought it was safe for dummies to run the clean-up and registry clean-up in their default settings, but it seems that may not be the case and some even advise not to run the registry clean at all!
If my clean-up goes wrong and something stops working, can I run windows restore after to recover or does CCleaner erase those files for good?
I look forward to hearing.
Regards,
Graham
Blind registry cleaning is never a good idea. In ccleaner or any other software
Instead of relying upon System Restore which can sometimes fail it's better to use a good disk imaging software and there's several available such as these two which offer a freeware version; Macrium Reflect, DriveImage XML, etc.
Originally there was also a free version of Easeus Todo, but then they only offered this for a price.
Recently a free version is back :-
http://www.majorgeek...ee_edition.html
There are of course many nice extras if you pay, but what you get for free is more than adequate :-
http://www.todo-back.../comparison.htm
On that comparison page, ALAN is quoted as endorsing their product with :-
"I know just enough to get in trouble and your backup software is the best in the market."
Please note that I AM NOT THE ALAN :o
Though I must admit that I am happy that when I do get into trouble, Macrium Reflect saves my bacon :)
Many thanks guys. I'll check out the links.
Just to be sure then, when Ccleaner tells me there are non-existent registry items or extensions, I should be careful (as I mentioned, I always back-up the registry beforehand)?
Yes (see my signature below)
I've never trusted the Windows restore function. I make weekly disk images with Macrium and backup my user data files every day.
My main desktop PC just went flaky this morning with several weird problems (I think I know what I did :(, and it wasn't the Registry). I decided to restore my last image and user data. Took a couple hours but I am back running without the bugs and lost no data. It was the shorter of trying to troubleshoot the several problems.
Image... backup... image... backup... image... well, you get the point. ;)
Yeah Macrium Reflect saved me from the issues caused by Microsoft's Update Tuesday from last week, those .NET Framework updates I loathe especially when they mess up the computer. I no longer troubleshoot, takes far to long and it's quicker and less frustrating to restore from a recent and known good backup image.
+1
The only problem I had was the Macrium Rescue disk wouldn't boot & I know I tested it after I created it in Aug. Since the PC wasn't totally dead, I was able to burn another one. That was scary.
+1
My Macrium Boot discs have never failed me - but I still do not trust that they will boot the next time.
Therefore whenever there is an extra benefit from a new update I will create and use the latest version - but keep all the previous versions in reserve just in case.
About 2 years ago when I first moved from XP to Windows 7 I failed to correctly prohibit any Updates from even downloading.
After one busy day of creating new documents and setting up desktop shortcuts,
I was horrified that a Microsoft update came crashing through and made my system unusable.
That destroyed Windows and wiped out a whole day of work that had not yet been backed up.
I plugged in the Macrium boot recovery CD and used it first of all to backup C:\ in its thoroughly trashed condition.
That took perhaps 8 minutes.
Only then did I restore the latest backup of a fully operational C:\ (taking about 6 minutes) and then boot back into Windows as it used to be before my last day of work.
Then I mounted the last good image as P:\ and the latest bad image as Q:\
and in less than 1 minute BestSync presented a tree comparison showing every difference between P:\ and Q:\,
and I ignored the chaotic differences between \Windows\...
and simply selected the differences between the desktop short-cuts and the user documents,
and copied to C:\ the latest shortcuts and documents that had been backed up by the Boot Recovery CD.
In less than half an hour I retrieved all the previous day's work that Microsoft update had destroyed.
I use the 64 bit portable freeware version at
http://www.risefly.com/fsedwld.htm
Well, this is weird. I restored the PC (WinXP desktop in my signature), no problem. The problems I was experiencing were gone and I used the PC for the rest of the day. I powered off the PC last night as usual. When I powered it up this morning, it took waaay longer to boot up (much HDD activity). When it finally came up, my same problems were back. :wacko:
I just ran a full virus scan (Norton) and it found no problems. Next I'm going to run MB & SAS to check for any malware. If that all comes back clean, I'll restore an older image. This is NOT what I had planned to do today. :angry: Futz time.
Edit: One of the problems I am experiencing is that IE will no longer start. No errors, it just won't start. I just tried to start MB which was already installed and got this error: Run-time error '339': Component 'ieframe.dll' or one of its dependencies not correctly registered: a file is missing or invalid. Sounds to me like MB depends on IE and since there is something wrong with it, MB can't run.
I may just have to restore the older image and start over. Grrr
Does the same thing happen if you start in safe mode?
Have you tried running SFC ?
When you said ''I think I know what I did'', do you feel like telling us what it was Nikki?
It occurred to me, hazelnut, after my last post, that what started as a direct response to a post, I've turned into hijacking the OP's topic, which I didn't mean to do.
Maybe I should start a new topic in the 'hardware' forum. What do you think?
Okay :)
Okay :)
I started a new topic here: http://forum.piriform.com/index.php?showtopic=39892
