Hi i want to ask if i reset my pc every week then my license will be cancel or not
What license? What do you mean reset?
i mean if i format my pc what is going to happne to my license
13 minutes ago, tnt1 said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> i mean if i format my pc what is going to happne to my license </p> </div>
Probably need to reinstall your software and re-enter your licence key? Depends which software you are referring to.
If it's the OS license, i.e.; Windows 10 it's either tied to your Microsoft Account. Or if you have a Local Account it's tied to your hardware.
