Reset ccleaner pro default settings
Hi, can anyone help me reset to default setting? I was messing about and I seem to have disabled a few links lol
See here
Hi, thanks for the reply, but my set up is different and I can’t find the reset. This is my screen
You are correct hazelnut’s leads to version 6 instructions. I’ve alerted a employee
That screen you show is health check, it has no defaults, or rather it clean what it cleans with no choices (except keeping certain web cookies). If you want control over what’s cleaned use custom clean
