Reported Cleaning Size
No matter the size of files sent to CCleaner it seems to say 26GB was cleaned, is there a limit to the files it can handle or is set to report 26BG only
Earlier 70GB was sent but reported as 26GB
Perhaps Windows failed to remove the 26 GB that you stipulated,
so they remained pending until the next time you ran CC,
and the time and time again there-after.
Perhaps you need to deal with write/delete permissions issues.
Perhaps you have designated their location through a reparse point that prohibits any damage to the destination contents.
Perhaps there are another hundred guesses to be made.
You need to tell us your Operating System and the exact file names and paths you targetted,
and the exact method you used to send them to CCleaner.
Windows 7
Files from folders MPEG
Using delete to recycle bin then running CCleaner
There is nothing shown in the recycle bin
As Alan says, some more info needed.
Do you know what size your Recycle Bin is set to?
It was set to 25894 so I guess that was the reason
Thank You both for the prompt replies
