Remove Web Published
HI,
I published to the web, looked at the contents and saw that really unique FirstInitial LastName in the User Profile information .
Search on that unique last name; find out where i work.
ARIN et al lookup based on company name; now you have public IP address blocks.
Attack away.
I really would like to remove it; isn't there any way to do it ?
Can the Pro version do it ?
Thanks for any advice
If you send the link generated from the 'publish to web' to someone else, when they open it info such as Windows License number etc is stripped out.
Try saving the link yourself and then opening it in another browsing session.
