Been using ccleaner for years and love it...but have a new computer that have windows 7 64bit installed and i uninstalled google toolbar and office 2007 from add/remove program but ccleaner still show them in the tab "Applications" so how can i remove those entries in ccleaner???dont have them on the puter soo why have them in ccleaner=)?!?any kind soul that could help me thanks
Copy/paste the following into Notepad (Start Menu >> type notepad in the Search box, and hit Enter), then File >> Save as.. >> type "programs.reg" (WITH the quotes - you can name it as you see fit, but the quotes must be there, and it must finish with .reg) into a folder of your choice.
Then double-click that file in Windows Explorer, and accept the prompt that will pop up.
