Remotely check if Ccleaner ran?
Hi Everyone,
I purchased the CCleaner network edition and it's working well. I have a few remote sites that do not have a connection back to the main network. On those systems, I installed the network agent that I built from within the network edition console. The only thing that is currently missing is my ability to confirm those systems are being cleaned.
so, two questions:
1) If I create the installation .msi from the network edition, when does ccleaner actually run once it is installed on a client machine?
2) Is there anyway to confirm it ran and cleaned? I'm hoping there is some form of log file I could scan to see the last successful cleaning with some type of result? I have some management utilities/agents on those remote PCs and I was hoping to use them to scan that log file for keywords or something to confirm it ran.
Any help would be greatly appreciated.
Thanks
As you purchased the Network Edition it makes sense for you to contact CCleaner support.
http://www.piriform.com/support
