Remote programs are not removed from the menu
Hi,
Your free-available program is the best!
But I found a bug.
It makes cleaning the computer and clean the registry.
As well as cleaning and third-party programs such as Auslogics BoostSpeed 8:
Cleaning your PC
advisor
Shoe register
Registry cleaner
and manually delete the folder from the "program files", but it still does not disappear remote program ...
Thank you.
almost all uninstallers leave evidence behind.
try looking in the usual places, like; Registry, Program Files and AppData
