How do I delete the Registry Values?
Please give detailed info, thanks.
How do I delete the Registry Values?Please give detailed info, thanks.
Do you mean the ones displayed when you clicked 'scan for issues' in the registry section of ccleaner?
If so just click 'fixed selected issues' next to scan
Don't just assume if an entry is there it has to be deleted. CCleaner is a very safe cleaner but you can never be to careful.
Also make sure you create a backup of the registry when it asks you to do so in case a problem later occurs.
If you mean in general this has to be done via the registry editor in start-run-regedit
But i think you should stay clear of that
