Eli
1
Hi
I have the following registry key reported as unused file extension:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.pf
A moment before that ,I uninstalled Google Earth, does it have anything to do with this ?
If it is some thing else, what is it?
Thanks
Could be prefetch files .
That is your decision really ![:)]()
Make a backup of anything you delete when you are unsure.
CeeCee
5
It's totally safe to delete it. Shortly; it's just a file extension that has not been registered to open with any application.
