When I run the registry editor I constantly have the same entry for about 2 weeks.
It says AC76BA86-7AD7-5464-3428-800000000003 Microsft/windows/current version/App Management/arp cache
After upgrading mozilla I had to do an uninstall and reinstall. Also the same with my antivirus software. I wonder if you can help me figure this out and advise me what to do. I have a constant buzz in the PC since. Thanks
The only thing I can find relating to your query is a possible problem with Adobe Reader. Have you recently installed, or removed this program, or have you had a problem with it?
Regarding having to uninstall your AV, that sounds quite serious. Can you provide more details?
Have a read here, and see if it relates to your problems.
