Registry Cleaner won't work; won't remove items.
Here is a screenshot of my laptop, of the registry items it will not remove. Help?
I don't see any screenshot.
Note:
* To properly clean the registry you need to have Admin rights.
* Some registry items you clean can come back if they're automatically created by a program that needs them.
Edit:
And to quote moderator Nergal's signature in regards to the registry cleaner:
DON’T JUST CLEAN EVERYTHING THAT’S CHECKED OFF.
ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU’LL BREAK IF YOU DON’T.
