Registry Cleaner Recommendation
I need a recommendation for a registry cleaner program. I appreciate any suggestion you have, and prefer this type of advice to the advertisement kind that I have found lacking.
Thanks
RegSeeker http://www.hoverdesk.net/freeware.htm
RegSeeker 1.52 is a very good registry cleaner but sometimes it seems a bit too aggressive in its cleaning. Users have complained about programs and settings that have been modified when they shouldn?t be.
To counter these problems Andavari has now created a customized exclude.ini file.
Downloadable from a post just above this one or goto here.
For over a year I'm using the excellent Registry Cleaner "MV RegClean" from Marcos Velasco Security.
It's a freeware, easy-to-use, reliable and a unbending trust application. I have not yet troubles with this useful program in these years.
You can download this application: MV RegClean or here
P.S. The native language is portuguese. I don't know if in the latest version there are the english installer. If no you can see the following screenshots to help:
Start
Scan
Options
