Registry cleaner not working
Hi , I have a problem with the registry cleaner. It identifies problems and seems to delete them, but when I run the cleaner straight after, the same problems reappear. Any ideas?
Thanks for the help, Tony
I suspect the returning entries are system generated so you’ll never get rid of them.
if you show a screen shot, that can be verified.
