Refund for unused product
I am unable to get a refund for unused products! I am sent round in circles trying to make contact with this company! The product itself is good. Support is impossible! By their ‘support’ they have made sure I will not buy their product for my new Mac.
This is a user forum so we do not have access to accounts/billing here.
If you want to manage and/or cancel your subscription then there is a webpage to use:
https://www.ccleaner.com/subscription-management
If you need to look up your Cleverbridge reference then see:
https://www.cleverbridge.com/?scope=cusecolp
If you need to look up your CCleaner licence key then use this tool: https://www.ccleaner.com/support/license-lookup
You will need to contact support for questions about accounts or billing.
To start raise a support ticket by using this contact form.
https://support.ccleaner.com/s/contact-form
it should also open a ‘Live Chat’ where a virtual assistant will try to help you.
Note that you HAVE TO engage with the chat - If you just fill in the form and leave then you will not get a reply.
