I am useing Microsoft windows 7 home edtion and when I am cleaning though cc cleaner, I get to where it is cleaning the recircle bin (at 35%) and won't go any further. I have unchecked the recircle bin so that the program winn finish running.
Please, hope someone can help me here.
chris
empty your recycle bin manually.
Hi chris.
You could have a corrupt Recycler, or a corrupt file in the Recycler.
Similar Issue here with Vista:
Deleting the Recycler will usually fix the problem, as Windows will create a new one when you reboot your PC.
Instructions here:
Windows will make a new one.
Hope that helps.
