Recycle Bin Settings
On win98SE, everytime CCleaner is run, the max size settings of recycle bin is changed to 10%. As a matter of practice, I keep it at zero. Therefore, everytime CCleaner is run, I have to reset to zero. Is there any tweak whereby it doesn,t interfere with recycle bin settings?? It doesn,t change settings in winXP.
i think its a fault in da CCleaner program. it does it to me as well. if u wanted it fixed, try paying a small fee and upgradin to the latest update.
:D
Go to options and unckeck the 2 recycle bin boxes. (assuming you haven't done so.)
It still does the same. Incidentally, I am using the latest version 1.22.142.
:D
Mr. Cleaner you say "try paying a small fee and upgrading to the latest update" what are you talking about CCleaner is FREE and no fee should ever be paid for it apart from a option donation
