Recycle Bin > Run CCleaner
wen u run CCleaner from the recycle bin ... u cant actually see the space removed etc etc ...
i would suggest that CCleaner would make a pop up in the notification are wen CCleaner finishes cleaning showing howmuch space emptied wen u run CCleaner .. another thing is that CC should have an icon in the notification are to just right click and run .. alternetive for the recycle bin > Run CCleaner ..
