Recycle bin options and Silent install
Hi there !
I would like to silent install CCleaner and to customize it with a ccleaner.ini file. I've found great documentation on Piriform's website.
But...
I can't find a way to disable the two options about Recycle bin context menu. During standard intall, we can uncheck two boxes. But what are the lines to add in a ccleaner.ini file ?
Thank you for your help ! :)
Govi
Hi there,
does anyone have a solution to disable these two options during silent install or with ccleaner.ini file ?
Thank you !
how about if you have a VBS script (or .BAT file) that copies the .EXE files and the .INI file from a USB stick to the Program Files folder?
your .INI file would already be setup the way you want, and the .EXE files are all that is needed when upgrading to the next version.
made even easier if you use the Portable build.
run the VBS script as Administrator, which it can self-elevate anyway, and have it create the Desktop shortcuts too.
Hi mta,
thank you for your answer :)
I haven't thought about this solution because I thought it was too "dirty" and I wanted to do a clean silent install. I'll try to do it with just copy/paste the .exe and .ini files !
the copy/paste solution is what I initially did, but got lazy and sick of the Windows warning "are you sure" when copying into the protected Program Files folder.
the VBS script does all the heavy lifting for me now as well as creating a desktop folder with shortcuts to CC and DF.
"clear recycle bin" not working on Win 10 - why?
not working how?
firstly, rule out a corrupt recycle bin, info here; https://forum.piriform.com/index.php?showtopic=42673
second, if files are remaining in recycle bin after running CC, check your setting for Only delete files in Recycle Bin older than 24 hours in Advanced options.
@mta - thanks for this tip.
On Windows 10, running CCC Pro 5.26.5937, CC is still not emptying the Recycle Bin.
I've made the changes under the Advanced Settings, and I can clear the RB manually. I've even restarted my Surface Book after making the above changes and CCC still does not clear out the Recycle Bin.
Any other suggestions before I open a Support Ticket?
--SWH
Did you run the corrupt recycle bin fix?
