Recycle Bin Not Emptying
Hello
CCleaner v5.30 on Windows vista 64bit sp2,
I just updated CCleaner today, now no longer emptying Recycle Bin.
in case your Recycle Bin has been corrupted, try this; https://forum.piriform.com/index.php?showtopic=42673
Thanks but I have already tested my Recycle Bin and I can use it normaly via windows,
I just thought this was worth reporting as a bug incase it is happening to others.
that is no guarantee the Recycle Bin is not corrupted.
if you don't want to do the steps in that posted link, that's fine.
but if that is what is causing your CC issue, then it will remain.
Hi mta,
I have I have carried out the steps in the link you posted for each drive in my PC.
However this has not changed the fact if I put some thing in the Recycle Bin and run CC it remains in the bin.
in CC, go to Options, Advanced and make sure Only delete files in Recycle Bin older than 24 hours is NOT checked.
