Recycle Bin not emptying
I have Windows 10 64 bit and this issue started last week so this is before and after the Anniversary Update
CCleaner v5.22.5724 64 bit
I have the box checked to empty the recycle bin but it does not empty it, I recently upgraded to the latest version of CCleaner a few days ago and this issue was not present on the older version
This is just a heads up for you guys, maybe its something on my end that i have not done
Thanks
Ken
Does the recycle bin empty if you DONT have the box checked and use ccleaner ?
Thanks for the quick reply. I unchecked and checked it mulitiple times and its still not emptying
to rule out a corrupted recycle bin, try this; https://forum.piriform.com/index.php?showtopic=42673
I dont hink my rc is corrupt, I can delete anythng I want and it goes into the RC and I can empty the RC on my own with no problems.
Try a clean install of ccleaner after uninstalling the one you have now.
https://www.piriform.com/ccleaner/builds
That worked , THANK YOU :)
