Recycle Bin Context Item Not Working
Running Windows 10 with current version of CCleaner. Suddenly context menu item "Run CCleaner" no longer works. Cleaning works via the desktop icon and reinstalling didn't fix the problem. I have the same setup on two other machines that are working fine.
Please see the latest Beta release which should fix this issue
that did the trick, thanks
