Recuva will not uninstall
OS XP Media Center Edition: Recuva has stopped working and will not uninstall.
Hi chapsieml, and welcome to Piriform.
Have you tried installing again straight over the top of your current Recuva?
This usually repairs a problem installation.
I tried a significant amount of things including your suggestion - nothing worked so I went to this forum and posted the problem.
I have since just fixed the problem by going into safe mode and un-installed the program. Then re-booted and and did another download of another fresh copy of Recuva and did the install.
The new install took and the program appears to be properly installed and working at this time, thank you.
Good news and well done with the safe mode uninstall.
That was my plan B.
