Recuva Secure Deleted
Can someone help me?
I have run the Recuva Secure Delete Highlited (Checked) function, the program has determined that the files were deleted. Actually written over and are unrecoverable. But when I run Recuva again, all the file names will show up again after the scan. Is there any way to delete the file names, ( ex. basketball.jpg) to be eliminated to not be seen?
Not with Recuva. Search the forum for this topic, which has been discussed many times.
Bose, I'll say this one more time. Download and install eraser 5.7. Check there info and follow the necessary precautions I.E. system restore off, do not defrag before using etc, then run "erase unused space" use 1 pass only as 300Gig takes about 7 hours. Once completed you will see no more file names. Post back and let us know how you get on.
Regards Richard...
