I am from the Netherlands and Recuva works best for me. Lot of files had green dot and are recoverd but the most recent files before my portable drive went fron 300GB to 32GB, have a red dot and can't be restored.
It says as reason: Ongeldig clusterbereik (invalid cluster destiny)
Is there something that I can do to resceu those files? Recuva shows me the exact names, how big the files are, when last modified but I cant restore. Is there any hope?
Without knowing all the details, it looks as if the cluster addresses have been modified on deletion by NTFS, which can happen if the files are highly fragmented.
If the drive has gone from 300 gb to 32 gb, can you reset it to 300gb, possibly with Partition Magic? You may have better luck then.
I don't know what exactly happend but the one moment everything was fine (NTFS) en the other day de portable drive became a 32GB Fat32 disk and all the other space became unallocated.
I then have modified the structure of the 32GB (did'nt touch the unallocated space) eith MSDos without formatting... soo the drive became a NTFS (hoped that that would give 5he other space back).
Is it possible to reset from 32gb to 300 gb without losing the data or formatting? The data is there, a lot restored but only those important files give a red dot with the reason invalid cluster destiny (not deleted or overwritten).
