Before I purchase Recuva I would like to know if this program will recover a deleted PROFILE from Windows 7.
I want the entire profile and not just files.
Recuva is free. What you pay for is support from Piriform if you buy it, the program is no different.
It is very unlikely that you can recover a deleted whole profile. You would probably be able to recover some of the documents but you said you are not interested in doing that.
I doubt if system restore would restore the profile either but you may want to give it a try.
